Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Avalanche
Old 06-21-2016, 04:35 AM
carl80 carl80 is offline
2002 avalanche z71 rear end identification
Sounds like I have a bearing going out and was going to replace all the bearingsame in the rearend while I'm at it. How do I know what rearend I have?
Old 06-21-2016, 07:34 AM
rhandwor rhandwor is offline
Re: 2002 avalanche z71 rear end identification
Look for a small metal tag attached to a bolt on the end cover.
Old 06-21-2016, 12:45 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
If there is no tag, take your VIN to any GM parts counter and they will be able to give you that information.
Old 06-21-2016, 06:09 PM
Blue Bowtie's Avatar
Registered Offender
Or you can do one of the following:
Read the RPO codes which are usually located inside the drivers door panel or glove box.
Clean off the right axle tube and look at the code stamped on the axle tube.
Chances are it's the 8.6" 10-bolt. Ratio will be defined by the RPO code, and so will the optional lockup carrier.
