Go Back   Automotive Forums Car Chat > Toyota > Corolla/Matrix/Voltz
Old 06-18-2016, 01:26 PM
Volunteer871 Volunteer871 is offline
2002 Corolla check engine light seems wrong
I have a 2002 Toyota Corolla. On a hot day (the first in a while), I got a check engine light for P0125. I'm going to clear it and see if it comes back. I think it is a false alarm for insufficient engine coolant. If the code and check engine light come back, what should I do?
Old 06-18-2016, 02:51 PM
MikeCStig MikeCStig is offline
Re: 2002 Corolla check engine light seems wrong
Check your coolant to be sure there is enough and that there isn't any air in the system. If that's all good, that means the sensor is acting up and will need to be replaced.
"Ok, systems check; the battery is discharging, the oil temperature is very high, the oil pressure is very low, the engine temperature is off the end of the scale, I'm running out of petrol... but the clock is correct!"
-James May, in an old, worn out Lamborghini purchased for less than £10,000.
Old 06-26-2016, 12:39 PM
How do I check if there is any air in the system?
Old 06-27-2016, 10:36 AM
somick's Avatar
somick somick is offline
Park your vehicle on a hill - nose up. Open the radiator cap and run your engine until it becomes hot and the thermostat opens. Air should escape and you should be good.
Good luck,
Sam
Originally Posted by RIP
Please post back when you fix it so we all will learn something
Tags
check , engine , light , p0125
