Old 06-16-2016, 12:13 PM
HeWhoKillz HeWhoKillz is offline
shift cable
i have a 98 dodge avenger v6 automatic transmission. where can i find a shift cable? I have called places like autozone that says it has been discontinued. Junk yards don't have any either. Where should I go?
Old 06-16-2016, 02:21 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: shift cable
Is the cable itself bad, or just the end of the sleeve that snaps in to a bracket? The reason I ask is because I have successfully 3D printed new ends to replace broken ones for door latch cables and that might be an option for you as well.
-Rod
Old 06-16-2016, 04:10 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: shift cable
The problem with junkyards is they usually cut the shift cables to remove the engine and trans. They'd rather save 30 seconds than to save a few parts someone might need.
All the v6 Avengers were automatic so that's a plus. Sebrings, Ciruss, etc were all basically the same car too so any of those with the 2.5 v6 will have the proper cable.
Old 06-17-2016, 01:44 PM
Re: shift cable
Do you know what year the sebrings and cirus I can ask for?
Old 06-19-2016, 10:06 AM
Re: shift cable
-Rod
The cable itselfbroke.I can longer shift it.
Old 06-19-2016, 12:15 PM
Stealthee's Avatar
Re: shift cable
A quick Google told me 95-00.
Old 06-20-2016, 11:49 AM
Re: shift cable
I asked every junk yard about the three cars and those years and I still told most of them are cut when they take the transmission out. Even if the sebring and cirus have the same transmission and cable will it be the same length?
Old 06-20-2016, 09:40 PM
Stealthee's Avatar
Re: shift cable
Yes. They are literally the same car with different bumper covers
