Old 06-11-2016, 09:06 AM
DamionD DamionD is offline
Mass Air Flow
Ok so I just replaced my mass air flow sensor about a week ago. My check engine light just came back on and when I scanned it it said mass air flow sensor. Any ideas what could be causing this to happen again? The codes are P0102, P0440, P0440.
Old 06-11-2016, 12:08 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: Mass Air Flow
P0440 is the infamous gas cap code. You will get this if the cap is not tight, also if there is a leak in the evap system anywhere.
Inasmuch as the P0102 - does this have the factory intake system (airbox) or has it been modified? Check the condition of the wiring leading to the MAF.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 06-11-2016, 12:39 PM
j cAT j cAT is offline
Re: Mass Air Flow
put the old MAF back in. common connector issues. new does not mean good.
Old 06-11-2016, 11:55 PM
Re: Mass Air Flow
To my knowledge the only thing that has been modified is there was a k&n filter put in it.
Old 06-11-2016, 11:56 PM
Re: Mass Air Flow
If the old one was plugged in the truck would just stall out when I started it.
Old 06-16-2016, 05:54 PM
Re: Mass Air Flow
I thought it was just the code problem not a stall problem.
should idle if the MAF is bad though.
I would check that you have NO leaks after the MAF. also again the connector /wiring/ also check voltages at the MAF you tube has a good video. you will need a frequency meter for ONE of the readings which is the MAF output.
only use MAF cleaner !!!!!!!! carb cleaner will kill it.
Tags
chevy , maf , massairflow , silverado
