Old 06-09-2016, 07:28 AM
GTRfan01 GTRfan01 is offline
paint question-coloured plastic bleeding through
hi all,
as the heading says, I would like other peoples recommendations about primering to stop coloured styrene from bleeding through.
I have a few kits in my stash molded in yellow and orange (why do they do this! its so stupid!) and before i start them i want to make sure it wont bleed through at the time of painting or over time.
i've done some searching on the forums but i havnt come to a conclusion yet.
i have seen this colour bleeding thing happen to other peoples models and cant afford it to happen to mine.
will a few good coats of tamiya/mr hobby grey primer do the job or do i should i use something else? maybe even a black primer? (ive seen 'army painter' black primer that is available to me)
Thanks in advance.
thanks in advance
Old 06-09-2016, 08:14 AM
sjelic's Avatar
sjelic sjelic is offline
Re: paint question-coloured plastic bleeding through
Tamiya spray primers work best for me, you need white for lighter colors, grey is good for darker shades, black primers I use as semi gloss black because they are the most uniform way to cover something in black, I don't use black for body
Sasa Jelic
SCALEMAKERS
The Following User Says Thank You to sjelic For This Useful Post:
GTRfan01 (06-09-2016)
Old 06-09-2016, 02:34 PM
mel79's Avatar
mel79 mel79 is offline
I think your best bet is to use sealer/sealant. Hiroboy sells pre-thinned sealer but you can probably find local automotive paint products for the same purpose too. Just be careful that they are not too hot for plastic.
Other alternatives that might work are silver basecoat or Future floorwax.
br
Mikko
The Following User Says Thank You to mel79 For This Useful Post:
Old 06-10-2016, 02:46 AM
RonCla's Avatar
RonCla RonCla is offline
I use B-I-N Sealer available from Bunnings. Its shellac based and prevents bleeding and hot solvent auto paints from getting to the plastic.
It needs to be airbrushed and wash up is done with Methylated Spirits.
It does come in a spray can but the spray pattern is way to much for a model.
https://www.bunnings.com.au/zinsser-...iller_p1561796
The Following User Says Thank You to RonCla For This Useful Post:
GTRfan01 (06-10-2016)
Old 06-10-2016, 06:22 AM
thanks for the replies. much appreciated.
