Go Back   Automotive Forums Car Chat > Buick > Rendezvous
Old 06-07-2016, 10:16 AM
Rookie#1 Rookie#1 is offline
04 rendezvous AWD & ABS problem
Car runs fine EXCEPT on occasion I get pulsing feeling when applying the brakes just befor complete stop. Also occasionaly the AWD disable and ABS light come on. They automaticly
reset after turning key off. Checked all brakes and replaced front pads otherwise everything in that area appears ok. Any suggestions?
Old 06-07-2016, 11:03 AM
Tech II Tech II is offline
Re: 04 rendezvous AWD & ABS problem
Have it scanned for ABS codes.....these are "C" codes....most scanners/code readers only read "P" codes....
The Following User Says Thank You to Tech II For This Useful Post:
Rookie#1 (06-07-2016)
Old 06-07-2016, 11:16 AM
Tech II do the auto part store scanners read both C and P codes?
Old 06-26-2016, 10:44 AM
Smile Re: 04 rendezvous AWD & ABS problem
A followup: Oreilleys ran the C codes for me. Problem turned out to be the
front right bearing/hub assy. I replaced the assy and all is good.
The Following User Says Thank You to Rookie#1 For This Useful Post:
Tech II (06-26-2016)
Old 06-26-2016, 12:57 PM
Thanks for reporting the fix....
