Go Back   Automotive Forums Car Chat > Mercury > Sable
Old 06-06-2016, 09:41 PM
ajnjohnson@hotmail ajnjohnson@hotmail is offline
Transmission
Hello, have a 2004 Mercury Sable with 52k.
Transmission stopped working unexpectedly.
Any ideas?
Old 06-07-2016, 11:40 AM
MikeCStig MikeCStig is offline
Re: Transmission
That's a pretty common problem with the Ford Taurus/ Mercury Sable of that period. It usually can't be fixed by flushing the transmission or minor repairs. The most effective option is usually a transmission rebuild or replacement. You can cross your fingers and try checking the shifter cable, but be prepared for the worst case scenario. If the cable is ok, your transmission is probably f*cked.
"Ok, systems check; the battery is discharging, the oil temperature is very high, the oil pressure is very low, the engine temperature is off the end of the scale, I'm running out of petrol... but the clock is correct!"
-James May, in an old, worn out Lamborghini purchased for less than £10,000.
