Go Back   Automotive Forums Car Chat > Chevrolet > Malibu
Old 06-06-2016, 08:50 AM
arcturusmine arcturusmine is offline
2003 Malibu high idle
I have a 2003 Malibu with 57000 on it. It recently started to high idle at roughly 2500 RPM. Could the throttle position sensor have gone bad? It will do this after it warms up.
Thanks,
Todd
Old 06-06-2016, 12:59 PM
Tech II Tech II is offline
Re: 2003 Malibu high idle
Have you scanned for codes?
Usually caused by a vacuum leak, bad IAC/wiring, or crud in the throttle body, causing it to stick open....
Old 06-06-2016, 02:33 PM
Thanks! Ill take a look a the vacuum lines first. It starts hard and you need to work it like a carb'ed engine when you first start it.
Thanks,
Todd
Old 06-07-2016, 05:57 AM
wpbharry wpbharry is offline
Could also be the alternator going bad.
