05 silverado oil guage reading
Got one for u guys. I had a check engine light on due to the fuel cap. I replaced fuel cap and disconnected the black battery wire with the key in the position for a few minutes to clear the error code. When I first started the truck the interior fan would only blow in the defrost position. After restarting the truck a couple of time this corrected itself. But this morning my oil gauge is pegged all the way to the right past all the numbers. Should I just disconnect the battery again? How long? Best tools to do this with? Used adjustable wrench last time because I couldn't get a socket in the space but it started messing up those small bolt heads.
Re: 05 silverado oil guage reading
FYI- i put the truck in gear and kept trying to start the truck in gear. The resets the cluster guages. After about 5 attempts it had worked its way back around. Works fine now. Probably happened due to s voltage spike when disconnecting the battery.
Yes when you disconnected then reconnected the battery with the key on you messed things up. I'm surprised you didn't get another check engine light. But hey as long as you got it sorted out now way to go.
Hey thanks for the reply. I did get another check engine light. It was for some kind fuel evaporator solenoid. The light is back off now though. I'm also thinking the truck may be idling a little low and rough or its my imagination.. I need to check again but I think is around 500 rpms this morning. I swore I had the ignition off when I plugged the battery back up. I think when I removed the black wire it made contact several times as i was unscrewing the bolt. This caused the spike.
This afternoon when I got off work rpms where 750. Then dropped to 550 after the truck warmed up. I'll check again in the morning. It just seem sluggish this morning.
with battery removal or the battery goes dead the idle speed needs to be re-learned that is how it works. on resetting of the PCM/BCM you disconnect the negative battery connections with the vehicle key in your pocket. you then short out the battery cables Not the battery LOL !!! This will reset the system allow 20 min or so for the reset to set. good luck . |
Thanks. So are u saying that u turn on the ignition after the negative is unhooked? U lost me a little on the shorting out part. Fyi- Evap vent selnoid has to be replaced, light came back on.
There is no need to wait 20 minutes for the PCM to reset. There is also no need to turn the switch on or "short" the cables. It resets almost the instant the battery is disconnected.
On that note to prevent issues like this in the future get yourself a cheap code reader. I picked up one for $15 shipped on eBay. Its not fancy or special but it reads and clears codes. If a code is manufacturer specific it will give you a N/A for the code, but you can still clear it.
THEN TURN KEY ON ..wait 20 min this discharges the power system so the PCM has to re-learn so it uses the stored programmed instructions when you re- connect the negative battery connection WITH THE VEHICLE KEY IN YOUR POCKET !!!!!!!. Not complicated , if it is don't mess with it . resetting the hvac system or the PCM must be done sometimes esp. with a battery going bad or someone screws up and messes with the battery connections with the key in the ignition.. also a good way to kill the PCM which maybe in you future . the evap codes are quite detailed on what the problem is many just change the gas cap then the solenoid and it goes on and on.. post the code so we can get a better Idea what the real problem is . good luck . |
Good call on the code reader, I hadn't priced them. Code P0499 was on there. When I go to buy the part, I'm going to have them check again.
many with the 2005-6 have had these coils open . I believe the part #is ac delco 214-2082 . you can remove the solenoid and measure the coil resistance should be low ohms like 20 or so. |
check the wiring also..
