Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 05-23-2016, 07:09 AM
JH32552's Avatar
JH32552 JH32552 is offline
Question Rain + a/c running = fogged up windows!!!!
The a/c in my 94 Camry still works fine, albeit a little warmer than I would like. I will be recharging the system soon, but would like to address an issue I have been having the last few years. If it's raining, and I run the a/c, all the windows fog up. What is the issue so I can fix it before refilling the system?
If it's a part, I hope it's a cheap one! LOL!!!!
Thanks guys!
Jackie :-)
Old 05-23-2016, 08:12 AM
brcidd's Avatar
brcidd brcidd is offline
Re: Rain + a/c running = fogged up windows!!!!
In the two cases I have seen of this complaint- it was always between 50 and 60 degrees out, rainy, and the recirc door was stuck open.
Defroster needs fresh air to properly defog the windows. So with that in mind, exercise your recirculation door, it should be opening and shutting, and you can hear the air flow difference as it works- other than that watch to see if it moves, or actuator is working. I have also tied them shut on folks who don't wish to buy a new actuator motor. Probably have to pull glove box out to access it.
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 05-23-2016, 08:18 AM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
If the fogging is occurring on the outside of the windows, then your inside temperature is too cold and you need to add some warm air to the A/C output. If the fogging is on the inside, it may be that your A/C is not operating well enough to remove the moisture from the air, or your A/C drain is partially plugged and you are getting water inside and wetting the carpet. Check your passenger side carpet to see if it is wet. The drain can be blown out from underneath with compressed air, gently.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 05-23-2016, 09:40 AM
JH32552's Avatar
The recirculation door operates fine with a very audible whooooosh when you exercise it. This fogging only happens when it's hot out, the a/c is on, and it's raining. I actually have to pull over, turn the air off, turn on the heat and defrosters to clear the windows. It's actually dangerous and happens rather quickly.
Old 05-23-2016, 09:44 AM
JH32552's Avatar
Hi Brian!
The moisture of on the inside of the glass. I've never noticed the carpet wet, but will definitely check that out today after I run the a/c. Seems to me, someone mentioned evaporator or a dryer or something a few years ago when having this same problem. But, maybe it just needs more freon... I have no clue! LOL!!! (that's why I am asking you guys! )
Jackie
Old 06-05-2016, 01:25 PM
JH32552's Avatar
FYI:
I topped off the refrigerant and she is blowing icy cold air again! YAYYYY! However, I haven't been driving in the rain yet to see if the windows are still fogging up. I'll post when I do! (keeping fingers crossed!)
Jackie
Old 06-06-2016, 10:41 AM
somick's Avatar
somick somick is offline
I used to have the similar conditions when my heater core got a hole in it. Check out your coolant level.
Good luck,
Sam
Originally Posted by RIP
Please post back when you fix it so we all will learn something
Old 06-06-2016, 12:49 PM
JH32552's Avatar
Good luck,
Sam
Thanks, Sam! I'll check that out! :-)
