Go Back   Automotive Forums Car Chat > Chevrolet > Malibu
Old 05-21-2016, 12:14 AM
Grocery guy Grocery guy is offline
2004 chevy classic...wont start
Please help......car wont start like not enough gas..changed the fuel pump and filter ...had to change the power connector to to fit the new pump..hooked everything back up ..pump sounds like its working..still wont start.....im pretty new to fixing cars so any advice would help thanks
Old 05-21-2016, 06:40 AM
maxwedge maxwedge is offline
A990 racer
Re: 2004 chevy classic...wont start
What car, what engine? Got spark to the plugs, will it fire if you spray carb cleaner into the intake?
Old 01-20-2017, 10:29 AM
Beejay7739 Beejay7739 is offline
I have a 2004 chevy malibu maxx. I am having a problem with the passlock system and the car will not crank or start. On this car I can't find the bundle of 3 wires on the ignition cylinder. There is a connection but it has 6 wires and none of them are black.
The car used to start, then it began to haze the intermittent cutting off problem. Now it wonk even crank. Changed the lock cylinder but still nothing. CAN YOU PLEASE HELP??? It's my only way to work. I'M GETTING DESPERATE.OF
Old 01-20-2017, 04:07 PM
A990 racer
Is the security lite on?
Old 01-22-2017, 12:56 PM
The red lite is not on but a yellow padlock lite is on.
When I changed the ignition cylinder I added length to the green plug in the cylinder. Could the wrong gage wire contribute to this issue?
Old 01-22-2017, 01:51 PM
A990 racer
The security sytem has you locked out. Do you have another key, if so do a relearn procedure, or try it with your single key, google the procedure, plenty of info out there.
Old 01-22-2017, 03:58 PM
I've already tried that several times to no avail. But I'll try different ones it one doesn't work. Thanks for the advice. Will let you know how it turns out.
Be blessed.
Old 02-04-2017, 02:27 PM
Originally Posted by Beejay7739 View Post
I've already tried that several times to noHD avail. But I'll try different ones it one doesn't work. Thanks for the advice. Will let you know how it turns out.
Be blessed.
Unfortunately, I am still not able to get the car started. I am at my wits end with this problem. HELP........
Old 03-22-2017, 07:57 AM
hotpipes hotpipes is offline
I found out why my 02 Malibu wouldn't start some times. After having the ignition key and ignition lock replaced twice I found out that my key did not have a chip in it and had nothing to do with it not starting. I found by replacing the casing or housing to the ignition starter lock assembly witch has all the wires attached to it, my car has never missed starting once. It took me about an hour. I purchased the part on Amazon for $45.00 dollars and found the help to replace it on YouTube.
Old 06-10-2018, 01:47 PM
jessy1592 jessy1592 is offline
where is fuel filter located on my car?2004 chevy malibu Lt
Old 06-10-2018, 09:40 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
I don't believe there is a serviceable fuel filter on that generation. The filter is in the tank and part of the fuel pump assembly.
