Old 05-16-2016, 01:31 PM
heine_ken heine_ken is offline
Question Vacuum Opens Throttle Plate
delete
Old 05-16-2016, 02:54 PM
harleyguy harleyguy is offline
Re: Vacuum Opens Throttle Plate
I have never heard of that happening. Have you put a vacum gauge on it? What is vacum at idle then in gear?
Old 05-16-2016, 03:00 PM
No, i unfortunately i don't have access to a vacuum gauge, and can't drive the car to a shop obviously. When the car sits in neutral, the vacuum seems normal, and also somethimes when you put it in drive. But after a little while, or if you tap the gas lightly, it exponentially opens.
Well, the forward momentum of the car is exponentially, the valve just opens maybe a cm.
Old 05-16-2016, 08:15 PM
brcidd's Avatar
brcidd brcidd is offline
Sounds like you are missing or have a broken throttle return spring- the vacuum comes from the engine- it will run wide open unless the throttle is doing its job "throttling" So the throttle opens very easily means there is not much holding it closed- thus a broken or misplaced throttle return spring IMO.
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
