Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > F-Body Problem Diagnosis
F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 05-15-2016, 09:00 AM
Heironiman Heironiman is offline
92 camaro rs v6 buzzing noise
Hey guys, I have a 92 camaro rs v6 3.1L and I've been having problems with battery drainage. I've switched out the battery and it still kept dying overnight when it was off. Now I've noticed that my car makes a buzzing noise at the back near the gas tank when it is off. I think it's the fuel pump and I think that's what's draining my battery. That buzzing noise thanks
Old 05-15-2016, 09:57 AM
Blue Bowtie's Avatar
Registered Offender
Re: 92 camaro rs v6 buzzing noise
Welcome Aboard!
Remove the fuel pump relay to see if the noise stops. If it does, the problem would be a failed relay or faulty wiring. If that does not stop the pump running, disconnect the oil pressure switch.
Old 05-15-2016, 10:27 AM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
If neither of Blue's ideas work you need to perform a parasitic draw test.
Old 05-15-2016, 12:37 PM
Tech II Tech II is offline
I think I found your problem....
down....
down........
Old 05-15-2016, 01:48 PM
Registered Offender
That would be worse than a failing relay.
