Go Back   Automotive Forums Car Chat > Toyota > Tacoma
Old 05-13-2016, 01:46 PM
t100 t100 is offline
1995 toyota tacoma
I have a 1995 Toyota Tacoma with a manual transmission that will not go into gear. How can you tell if it is the clutch or the slave cylinder that is bad?
Old 05-13-2016, 03:08 PM
MikeCStig MikeCStig is offline
Re: 1995 toyota tacoma
If the slave cylinder were bad, you'd be able to feel it through the pedal. It would probably go to the floor with little or no resistance. If the clutch itself were bad it would start making some bad noises when you push the pedal in with the engine running, or the pedal might get stuck.
"Ok, systems check; the battery is discharging, the oil temperature is very high, the oil pressure is very low, the engine temperature is off the end of the scale, I'm running out of petrol... but the clock is correct!"
-James May, in an old, worn out Lamborghini purchased for less than £10,000.
The Following User Says Thank You to MikeCStig For This Useful Post:
t100 (05-13-2016)
Old 05-13-2016, 08:14 PM
harleyguy harleyguy is offline
Get under it and have somebody press the clutch see if the clutch fork is moving. If no try bleeding the system make sure you are getting pressure to the slave cylinder. If no pressure you have a bad clutch master cylinder.
