Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 05-11-2016, 07:15 PM
ARK51294 ARK51294 is offline
wont start 1 click
98 1500 4x4 quad, 5.2.. Did run fine. Go out to start wont start just clicks once. Replaced starter and the battery. Still only clicks once. checked voltage across terminals to the grounds. swapped relays around still one click. Going to check in the morning make sure it didn't seize. any ideas greatly appreciated..
Old 05-11-2016, 08:23 PM
harleyguy harleyguy is offline
Re: wont start 1 click
Were you getting full 12.6V to the starter both on the main wire and the smaller wire when you turn the key. How are your battery connections? (Clean and tight)
Old 05-11-2016, 08:55 PM
Battery connections have been redone. new terminals. didnt check voltage to the starter will do that tomorrow morning. when i have someone to turn the key for me
Old 05-13-2016, 07:12 PM
Needed to replace the positive battery cable...
Old 05-14-2016, 06:22 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Is it ok now?
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
