Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series > N-Body Problem Diagnosis
Old 05-06-2016, 09:05 PM
jparks04 jparks04 is offline
1972 cutlass supreme 350 4 bbl. ignition spark when key is turned off
I am not getting a spark when trying to turn over my engine, instead I get a spark when I turn the key in the off position. Any suggestions?
Old 05-09-2016, 06:52 AM
j cAT j cAT is offline
Re: 1972 cutlass supreme 350 4 bbl. ignition spark when key is turned off
not good info explain ............
Old 05-09-2016, 10:08 AM
Tech II Tech II is offline
You get spark, when the magnetic field around the coil, collapses...when you turn your key to off, the field collapses, and you can get a spark......
Now the question is, is this the old points system in the distributor, or was it ever upgraded to an HEI system?
If the original points system, check the points.......I have seen the rubbing block come off, so when the distributor rotates, the points never open....points could also be pitted, open(too big a gap).......could also be a bad condenser....
HEI, either open pickup coil or bad ignition module....
