Go Back   Automotive Forums Car Chat > Renault > Mégane
Old 05-04-2016, 02:15 PM
samer1975 samer1975 is offline
Renault megane 1 2002 When To Change Oil gearbox automatically?
To all you reno owners out there with an AL4/dpo,these units suffer from solinoid valve problems ,along with people putting in the wrong fluid Only use FULLY SYNTHETIC
Because they suffer from cooling problems ,the hand book refers to
Spending to long in traffic /to long on the motorway /pulling to heavy loads,they go on to sat that you should put a themostat in that has a lower value,all of this points to overheating the fluid the condition sensor then flags it up to the computer,
If you replace the 2 regulator valves with the Borg warner ones you will have to upgrade the software otherwise your back to square 1
Renault will tell you the fluid will last the life time of the car with a top up now and again ,every other mfg will tell you to change the fluid every 30,000 m .
Some Renault transmission's do not have a drain plug they only have a level plug ,if you do not change the fluid you will be pumping
Debris from the friction material from the clutches and steels around the system this can damage valve body components o rings,bearings,bushings,solinoids
Old 05-16-2016, 12:30 PM
Re: Renault megane 1 2002 The Best fuel System Cleaner
Recommended To Use Every 10000 BG K44 BG 44K the best, fastest acting, safe, fuel injector cleaner. BG 44K cleans the entire fuel system including injectors, intake valves, piston tops and combustion chambers. If you have tried Techron, Sea Foam or other fuel system cleaners, try BG 44K it works. BG 44k has also been successful in returning fuel level senders and gauges to normal operation
& BG CF5, Carbon Fighter 5 fuel additive. BG CF5 is a blend of the famous BG 44K and BG Supercharge. For gasoline engines the CF5 will clean and stabilize the fuel system. For engines that see infrequent operation, collector vehicles, boats, bikes and during storage. Also excellent between BG 44K treatments. CF 5 stabilizes fuel when not in use and cleans when the engine is running. BG CF5 also protects against ethanol
