Old 05-03-2016, 11:42 AM
silversurferhdz silversurferhdz is offline
Send a message via ICQ to silversurferhdz Send a message via AIM to silversurferhdz Send a message via Yahoo to silversurferhdz
1997 Chevy S10 4.3 Vortex New complete ac system not working
I have a 97 chevy s10 4.3. Did a complete new ac system installation. Install new ac pump and put oil in holes, new condensor, new accumulator, new evap core, orifice tube, ac hoses. Did a vacuum for a couple of min it went to -28 closed the manifold gauges and turned off vacuum pump..waiting 30mins it held -28. Next added freon and put about 3 cans of freon. System took freon starting cooling fine. Ran truck for about two hours then heard some noises near glove box then ac started losing its cool slowly. Did i over charge? not enough oil in compressor? Did i damage compressor? How can i check compressor before i buy another..
Old 05-03-2016, 12:33 PM
brcidd's Avatar
brcidd brcidd is offline
Re: 1997 Chevy S10 4.3 Vortex New complete ac system not working
Number one cause of mobile A/C failure is loss of refrigerant due to a leak. What is pressure of system as it sits with engine off? If less than 47 psi, the evaporator freeze protection switch will not allow compressor to come on, you can test by jumpering the connector to the switch on the accumulator. But chances are real good you lost most of your refrigerant - especially since you said it gradually stopped cooling. Look for oily residue about any and all refrigerant line connections- there are times when systems will hold vacuum, but leak under pressure and vice versa.....so a pressure check is in order first.
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
