Old 05-02-2016, 03:45 AM
Jeffyp Jeffyp is offline
Electrical issue
I have a 98 gp gt. I have no power going to the radio, sunroof, steering wheel controls, or power windows in the fuse panel I have virtually ripped this car apart and still no clue why I'm not getting power. Any help is greatly appreciated.
Old 05-02-2016, 10:31 PM
Tech II Tech II is offline
Re: Electrical issue
Check the RAP relay circuit......first try swapping out the relay with another with the same number.....If that doesn't work, pull relay and check for power with test light on two of the legs.......if ok, jumper ckts. #142 and #75.....if you have power to your circuits now, then the control circuit to the RAP relay is the problem...
Old 05-06-2016, 07:39 PM
So where am I running the jumper wire to and from?
Old 05-07-2016, 04:28 PM
DrRadar DrRadar is offline
Just a guy
The accessory time delay relay (RAP) shown in the diagram above is located "behind the right side of the IP, mounted to the IP cross beam, above the fuse block" per the FSM. Jumper pins A2 (red wire) and C1 (dark blue wire) on the connector.
Lloyd
18 Charger ScatPack 392
18 Lincoln Navigator L (Hers)
98 Grand Prix GTP Sedan (RIP)
99 Grand Prix GTP Coupe (to the moon)
05 Wrangler Unlimited (Junior's)
03 Explorer XLT (Sissy's)
