Go Back   Automotive Forums Car Chat > Mitsubishi > General Discussion
Old 05-01-2016, 12:39 PM
jprebble jprebble is offline
Exclamation Split hose leaking oil driver side interior
I have a Mitsubishi Space which has a thin hose running down the drivers side underneath the carpet, parallel to the fuel door cable, which has a crack in it and is leaking oil. The oil is a clear yellowish colour. Is it brake fluid for the rear brakes? If not any ideas what it is? Would like to try and fix myself if possible...
Old 05-01-2016, 02:04 PM
MikeCStig MikeCStig is offline
Re: Split hose leaking oil driver side interior
Under the carpet inside the car? That's seems like a peculiar location for a brake line, but brake fluid (like most other types of hydraulic fluid) is a clear yellowish color.
"Ok, systems check; the battery is discharging, the oil temperature is very high, the oil pressure is very low, the engine temperature is off the end of the scale, I'm running out of petrol... but the clock is correct!"
-James May, in an old, worn out Lamborghini purchased for less than £10,000.
Old 05-01-2016, 06:35 PM
brcidd's Avatar
brcidd brcidd is offline
Do you have a rear wiper?- if in a hose it may be rear wiper washer fluid- which would be easy to fix--just cut out the bad section and splice in new hose.
I've never seen brake lines be rubber inside a car- they are always steel and under the car...
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Tags
broken , interior , leak , oil , pipe
