Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 05-01-2016, 08:42 AM
Jadewar Jadewar is offline
Unhappy 2001 Tahoe climate control HELP!! Please
Please help me... We have a 2001 Tahoe that is stuck on defrost. The rear vents work and blow fine... My hubby already tried disconnecting the battery and that didn't work. It is hot here in Texas and that defrost aint cutting it. Are there any quick fixes?
Thanks in advance,
Jade
Old 05-01-2016, 09:35 AM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: 2001 Tahoe climate control HELP!! Please
It's probably a blend door actuator problem.
Old 05-01-2016, 11:30 AM
j cAT j cAT is offline
Thanks in advance,
Jade
with the problem you have and its age stuck in defrost may mean a new HVAC control unit. disconnect the battery ground connection then place this wire on the positive so that the vehicles system is shorted out [NOT THE BATTERY] then after a 30 min period reconnect the battery ground cable and turn ignition to on see if it resets. this is I am guessing stuck in defrost and thats all it does is not respond to your commands/button pushing. sometimes vehicles can have a quick fix , most times it will cost you much time/money. esp on a vehicle this old.
Old 05-01-2016, 02:56 PM
Thumbs up Re: 2001 Tahoe climate control HELP!! Please
Thank you so much for your quick responses... Family takes longer to respond to text messages... Anyway, the problem is fixed, or at least temporarily. The handy man hubby looked above the gas pedal and found the little white gear thinggy and it was stuck i guess. I really do appreciate you guys though.
Old 05-07-2016, 05:01 PM
that would be a stepper motor door operator . yes than can stick or debris will also do it. some have found lizard in there .
