Old 04-30-2016, 09:22 AM
tinkering's Avatar
tinkering tinkering is offline
In the 200 Club
Question 99 GMC Jimmy V6 Cranks Doesn't Start
I don't see any recent threads on this and I want to have some dialog. I am starting this thread for a young friend of ours. Apparently he doesn't have a computer where he is. I am going to get him going on this site in the future though; there is nothing like first hand information.
1999 GMC Jimmy. He said 4.2 L V6 but I think that would be a 4.3 L, mileage unknown at this point.
He has lots of crank power; it's turning over good.
He can hear the fuel pump coming on.
When we get in touch with him I will ask if there is anything strange going on with the dash gauges (he didn't mention that so I assume not).
At this point I don't even know if 'Check Engine' is lit. He won't have a code scanner out there.
Is there a way to check the fuel pump without having a pressure gauge there?
Could it be a severely plugged fuel filter?
Should he check for spark at a few of the plugs? (pull the plug, put SP wire back on, ground plug, turn engine over, blue spark, etc)?
Are these electronic ignition modules a common failure?
Would a code scan with engine not running be of any value?
That is all I will say until I hear from someone here.
1923 Model T 'Stake' Truck, see in Legends of the Fall
1949 Chevy 3/4 Ton, had 214 ci now 235ci
1959 Dodge Mayfair
1986 Ford Ranger 4 cyl
1993 Pontiac TransSport 3.8
1996 Chevy 3/4 Ton 4x4
1999 Oldsmobile Alero
2004 BMW 330i
Old 04-30-2016, 10:27 AM
harleyguy harleyguy is offline
Re: 99 GMC Jimmy V6 Cranks Doesn't Start
Start by checking spark those caps and rotors are notorious.
