Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 04-29-2016, 05:17 PM
jinx10000 jinx10000 is offline
2004 Mustang gt - bogging down
Not sure if this is the right area for this.
I've been looking for a Mustang in my area on Craigslist for several weeks. Trying to find something decent within reason on price. This is the closest thing I've seen.
This one states:
Stage 2 build with comp cams
bbk throttle body
long tube headers with exhaust
bigger injectors
new coil packs
ported intake manifold
Excedy 2 racing clutch
Been SCT tuned but needs to be dyno tuned
Think it's dumping too much air vs fuel for program on it
I contacted him and asked him what that meant. He said runs fine at idle and almost bogs down on him when he gets down on it
Is it reasonable to assume a dyno tune would fix this issue where a SCT tune wouldn't?
Any questions I should ask?
Anything I should look for or try?
Should I just stay away from this?
Thanks for any help.
Old 04-30-2016, 01:47 PM
MikeCStig MikeCStig is offline
Re: 2004 Mustang gt - bogging down
Bogging down with throttle application suggests just the opposite. It may be running too rich. I would agree that the air/ fuel mix needs adjustment. Find out if it backfires or spits black smoke when it bogs down.
"Ok, systems check; the battery is discharging, the oil temperature is very high, the oil pressure is very low, the engine temperature is off the end of the scale, I'm running out of petrol... but the clock is correct!"
-James May, in an old, worn out Lamborghini purchased for less than £10,000.
Old 04-30-2016, 05:04 PM
Thanks for the response. I'll ask him.
Old 05-01-2016, 01:36 PM
He apparently sold it or got tired of my questions. Thanks again.
