View Poll Results: What should I do?
Crack somewhere in tranny 0 0%
Bad clutch plates 0 0%
Voters: 0. You may not vote on this poll
Old 04-27-2016, 02:46 PM
CadenD. CadenD. is offline
Ford Mustang GT No idle
Recently my 98' Mustang GT has starting to have what I believe is transmission issues it's an automatic. When I put it into drive there is no idle speed, I have to raise my RPM's to a non specific height from 1000-4000 just to get the vehicle. It runs fine after it is worked into gear, but if I floor the peddle the RPM's will free idle until I release the gas then it gives a hard shift into the next gear. I think I may have an internal crack, but I'm not sure.
Old 04-27-2016, 07:19 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: Ford Mustang GT No idle
Have you checked the fluid level?
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
The Following 2 Users Say Thank You to silicon212 For This Useful Post:
CadenD. (04-27-2016)
Old 04-27-2016, 07:34 PM
Yes I have multiple times. It was full twice, then It was low about between hot, and cold on the dip stick while at operating temp. I gave it one quart, and it now it shows it is over filled. A mechanic used a bottle of seal rejuvenator, but that didn't do anything either.
Tags
1998 , ford , mustanggt , transmission
