Old 04-25-2016, 08:20 PM
tuffy65 tuffy65 is offline
Miss fire on #1 and #3
I have a 2001 ford windstar the codes are bank 1 lean ( wires have been cut) could this cause the miss fire on the #1 and 3 cylinders? The previous owner put copper plugs in it instead of platinum. How hard is it to change the plugs?j
Old 04-25-2016, 09:30 PM
harleyguy harleyguy is offline
Re: Miss fire on #1 and #3
No the cut 02 sensor should not cause miss fire. I would suspect coil pack do you have good spark at the plugs.
Old 04-25-2016, 10:10 PM
I have not checked for spark trying to do the cheapest first
Old 04-26-2016, 08:28 PM
scubacat scubacat is offline
Copper plugs will simply wear out faster (30-50K or so), but won't cause problems being copper. If the plugs aren't Autolite with the single ground electrode, THAT could be a problem. However, almost always it's that coil pack as the previous poster indicated. Take it off, flip it over, and look on the bottom for tiny cracks. It's a common failure.
The Following User Says Thank You to scubacat For This Useful Post:
tuffy65 (04-27-2016)
Old 04-26-2016, 08:41 PM
It's not expensive to pull a wire and see if there is spark there.
The Following User Says Thank You to harleyguy For This Useful Post:
Old 05-08-2016, 12:09 PM
Turns out to be the coil pack.thanks
Old 05-09-2016, 09:54 AM
It usually is on these vans. Thanks for following up and letting us know!
