Go Back   Automotive Forums Car Chat > Dodge > Durango
Old 04-20-2016, 09:43 PM
Lougibb Lougibb is offline
What part is it?
Hello. I have a 2006 dodge durango,4.7 liter. I drove it for five miles and the temperature gauge shot up. Got it home and it started spewing coolant. It's coming from the casing behind the thermostat housing. Not sure what part it is or what caused it to leak. It's on the passenger side of engine. Has a pulley on it. Seemed to be pouring out of the gasket there. It's my daily driver. Any help would be greatly appreciated. Thanks
Old 04-20-2016, 10:56 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: What part is it?
Any chance you can post a picture of the part that is leaking? Based on your description I'd guess you're referring to the water pump, but having a picture would sure help identify the part.
-Rod
Old 04-20-2016, 11:08 PM
Thanks for replying. I found some diagrams online. It's the water pump.should I replace anything else while I got it opened up?
Old 04-21-2016, 01:28 AM
harleyguy harleyguy is offline
I'm pretty sure these are the ones that have a little hose coming off the top for the few extra dollars I always replace it. Just because it's a pain if you have to do it later.
Old 04-21-2016, 06:50 AM
shorod's Avatar
SHO No Mo
Right, if it has a bypass hose, replace it. You might consider replacing the thermostat and gasket while you have the cooling system drained. And if you are in to preventive maintenance, you should replace the upper radiator hose, lower radiator hose, heater hoses, and radiator pressure cap along with installing fresh coolant.
-Rod
Old 04-21-2016, 06:58 AM
shorod's Avatar
SHO No Mo
-Rod
