Go Back   Automotive Forums Car Chat > Oldsmobile > Bravada
Old 04-20-2016, 02:08 PM
scotty55 scotty55 is offline
New EGR Valve
Hi I have 97 Bravada that had a bad egr valve I replace it with new one and when its plugged in it still runs rough and has random miss firer. Run with it unplugged runs better but still a dog with no power .
Old 04-20-2016, 07:58 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: New EGR Valve
Your computer might not know it's there.
You might try a re-boot by disconnecting the negative battery cable for 20 minutes, turning the headlight switch on for a second to be sure nothing is holding a charge like a capacitor, then re-connect the battery cable and test ride.
Old 04-22-2016, 04:09 PM
Re: New EGR Valve
Yes sir I did that . Seem to run ok at low speeds getting on the freeway it cuts out tranny shift down and then it bogs down. Get off gas tranny shift back up but still no power.
Old 04-22-2016, 04:23 PM
AF - Advisor
Re: New EGR Valve
Is the Check Engine light on?
It sorta sounds like low fuel pressure too.
Old 04-22-2016, 08:08 PM
Re: New EGR Valve
Yes check light is on . That was going to be my next guess. I will have it tested
Old 05-05-2016, 07:48 PM
AF - Advisor
Re: New EGR Valve
Find out anything?
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
