Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 04-10-2016, 01:12 PM
89 Caprice 89 Caprice is offline
Unhappy 89 Caprice LS BR., no dash lights ???
Hi, I am new here. I recently purchased an 89 caprice, the instrument lights will not work but the floor lights come on instead (stay on). I was talking to previous owner, he said only problem he ever had was cig. lighter blowing fuses and horn not working. Not sure if he was doing some backyard wiring or not? I do know when cig. Lighter is used( fuse blows) the horn and stereo wont work? The key switch does not work in the car, will start without keys? All other lights work perfect. Need help please!
Old 04-11-2016, 10:43 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: 89 Caprice LS BR., no dash lights ???
Check all of your fuses. Check the fuse for the dash lights. Also check your tail light fuse ... if that is blown sometimes the dash lights will not come on. The floor lights are activated by the door switches - does the dome light stay on too?
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 04-13-2016, 07:51 AM
Thanks for the reply, no bulb in dome light, I guess it was taken out so he could run with the floor lights on (glows red). Floor lights come on when the park lights or headlights are used.
Old 04-14-2016, 11:23 AM
silicon212's Avatar
Confoundingly Lucid
That'll do it, too ... and pretty effectively at that ... Glad you got it taken care of.
The Following User Says Thank You to silicon212 For This Useful Post:
89 Caprice (04-17-2016)
Old 04-17-2016, 10:02 AM
Thanks silicon212, it was a loose fuse in the fuse panel, pushed it into place and works perfect.
