Old 03-30-2016, 07:54 PM
Shmitty Shmitty is offline
03 4.3 engine bogs down with accelerating
03 s10. The truck idles fine. Whenever I throttle it bogs down and wants to shut down
Old 04-11-2016, 02:48 PM
MikeCStig MikeCStig is offline
Re: 03 4.3 engine bogs down with accelerating
This sounds like an issue that boils down to fuel or fire. Start with the spark plugs. Pull them and check for carbon build-up (dry and black) or oil residue (sticky and black). If you find either of these things, you need new spark plugs. Check the plug wires for any obvious physical defects and test them for continuity. Check the ignition coils for adequate voltage.
If all of those things are ok, it's time to look at the fuel system. Start with the injectors. If they're dirty, they'll spray the fuel in more of a stream, rather than the fine mist it should be. Check the fuel lines for leaks, kinks, or blockage. Check the fuel filter(s) and the fuel pump. If your check engine light is on, get the code checked and that may point you in the right direction.
"Ok, systems check; the battery is discharging, the oil temperature is very high, the oil pressure is very low, the engine temperature is off the end of the scale, I'm running out of petrol... but the clock is correct!"
-James May, in an old, worn out Lamborghini purchased for less than £10,000.
Old 04-11-2016, 04:47 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
It could also be a catalytic converter issue.
Old 04-11-2016, 08:12 PM
harleyguy harleyguy is offline
Yes I would start with ignition. Check the cap and rotor well those things have a bad habit of carbon tracking. I have also seen a melted cat plug up and restrict flow. Get a fuel psi gauge and see if psi drops out under load.
