Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 03-23-2016, 12:33 AM
jeepgc02 jeepgc02 is offline
signal lights / hazard lights dont work help!!!!!!
so my left turn signal wasnt working i took out the flash relay solderg it back together my mistake was that i soldered all the connections together .. i put it back on and my signal was working but i turned on my hazards and they all stoped working now i changed the relay to a new one and checekd my fuses but they still dont work what can it be???? please helpp
Old 03-24-2016, 07:45 AM
rhandwor rhandwor is offline
Re: signal lights / hazard lights dont work help!!!!!!
First check all the bulbs a bad bulb will prevent a turn signal from flashing. Is the flasher working or did you change a relay.
Old 03-29-2016, 01:56 PM
They all work when other lights are on I tried fixing the flasher relay by soldering the points but I soldered them all together and the left and right turn signal worked but when I turned on my hazards they all stoped working I know I made a mistake in soldering all the points together but I can seem to find what the problem is I checked the 15amp fuse underneath and it's good I tried a new relay flasher but still wont work.
Old 03-29-2016, 04:22 PM
I would look at the hazard switch first as they worked until you tried the hazard switch on.
