Go Back   Automotive Forums Car Chat > Chevrolet > El Camino
Old 03-22-2016, 03:48 PM
Jacobswift70c10 Jacobswift70c10 is offline
66 El Camino oil pan removal
So I recently bought an el Camino from my uncle that has been in my grandpas barn for about 20 years. I want to remove the oil pan to clean out any sludge that may be in the pan but it looks like the pan is too long to take out without hitting a cross member. I have no way to take the engine out all the way. So would I have to lift the engine to get the oil pan out? If so how high? What else besides the engine mounts would I have to loosen?
70 C/10 250
66 El Camino 327
57 Bel Air 265
55 Cameo 265
27 model T
Old 03-25-2016, 02:31 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: 66 El Camino oil pan removal
You will need to remove the distributor cap and set it aside so it doesn't break. You will be needing to lift the engine approx. 3" on either side. A piece of 2x4 about 6" long works well for this. You will have to remove the exhaust system.
Once you lift the engine, you will be able to remove the pan.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
The Following User Says Thank You to silicon212 For This Useful Post:
Jacobswift70c10 (03-25-2016)
