Go Back   Automotive Forums Car Chat > Nissan > Nissan 350Z/370Z | Infiniti G35/G37 Coupe
Nissan 350Z/370Z | Infiniti G35/G37 Coupe Includes the VQ35DE, VQ37VHR - Z33 and Z34.
Old 03-19-2016, 01:16 AM
Bilonix Bilonix is offline
Question 350z engine
So I have a 2004 350z roadster, VQ35DE engine I believe. Semi-Auto version with the speed shifting.
I like to use the speed shifting when I drive with it, I switch first gear at about 4k and 2nd at anywhere from 3k to 6k.
Its been a well maintained car and hasn't had engine problems, what im asking is if it's terrible to be shifting at mid-high revs so often with the speed shifter thing it has haha.
does the engine in the 350z like high revs like other sports cars do? It has a nice powerband in 2nd gear for sure.
P.S. Damn does it ever guzzle gas hahaha.
Old 03-20-2016, 02:41 AM
MikeCStig MikeCStig is offline
Re: 350z engine
With strong, solid engines (like most Japanese engines) the only thing high RPMs are bad for is your fuel economy. Keep up with your oil changes, check the oil level often, make sure your cooling system is always full and never leaking, and your engine should be fine.
"Ok, systems check; the battery is discharging, the oil temperature is very high, the oil pressure is very low, the engine temperature is off the end of the scale, I'm running out of petrol... but the clock is correct!"
-James May, in an old, worn out Lamborghini purchased for less than £10,000.
