Go Back   Automotive Forums Car Chat > Chevrolet > Venture
Old 03-15-2016, 12:40 AM
Isitworthit Isitworthit is offline
2002 Chevy venture electrical problem
I am having problem with the battery light coming on headlights on when switch is off the fule gauge dancing up and down radio works intermittently that's when I start the van it will only run a few miles and the battery will go completely flat I have changed the starter do not believe it is the alternator as there to many electrical problems thinking that a short somewhere can anyone PlEASE give advice as where to start and what to look at thanks
Old 03-15-2016, 08:45 AM
aleekat aleekat is online now
Re: 2002 Chevy venture electrical problem
You need to test the alternator to rule it good or bad. Battery dropping below 12v can cause all type of symptoms. I would be checking battery cables, specifically all grounds.
Post back, that's what makes Forums Work.
The Following User Says Thank You to aleekat For This Useful Post:
Isitworthit (03-15-2016)
Old 03-15-2016, 08:47 AM
brcidd's Avatar
brcidd brcidd is offline
I'd look at it as the alternator is causing all the electrical gremlins- system voltage drops can cause all kinds of havoc- so have the alternator tested- can be done on car at any autozone etc. System voltage needs to be 12.5+ at rest and near 14 or more when running. Internal battery shorts or even bad battery connections can also cause your issues.
Your battery light on is your biggest hint- chances are real good your alternator is going South...
If you charge battery and it runs a few miles, then quits, then you are not putting juice back into the battery- Put a DVOM on the battery terminals when running- better be near 13+ volts or you will die again due to bum alternator.
The vehicle battery light comes on at about 10.5 volts- system voltage- so you can believe that if you can't confirm with DVOM.
Radio will die near 9 volts- and gauges go crazy on low voltage- so every indicator you have tells me system voltage is low- not any shorts anywhere. Shorts would blow fuses.
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 03-15-2016, 06:25 PM
Thanks when I put battery on charger little black and decker it.say alternator ok fully charged reads 13v so maybe I will take out and test at auto zone
