Go Back   Automotive Forums Car Chat > Saab > 9-3
Old 03-14-2016, 10:28 AM
Bobby7032 Bobby7032 is offline
Rough Idle and loss of power
Hello -
SAAB 2007 9-3
Recently my car has been having a rough idle and stalling on start up. It has been getting worse and I need it fixed ASAP for a long trip coming up. I cannot have this thing die on me while I'm 300 miles from home =(
At stop lights the car will have a rough idle while in park and reverse. While in neutral, nothing. As soon as I accelerate, it goes away but does have a lack of power if I really push the pedal. Once I am in 3rd/4th gear, the car feels normal with no issues. If I am on the highway and slow down then need to accelerate, it goes back to losing power BUT if I change over to manual and downshift, car gains power and goes back to normal.
Here's what I have done so far:
1. Changed the spark plugs twice. Once with cheap ones, the second time with expensive ones. I also swapped out the boots.
2. Cleaned the MAP sensor
3. Cleaned intake sensor
4. Replaced air filter
5. Changed oil
6 New battery
The engines gives no codes whatsoever and I have taken it to a couple places and their readers don't see any codes. My SAAB has a built in fuel filter and this cannot be replaced unless you replaced the whole pump (to my understanding). I plan on buying some Seafoam today and see if that helps. Also, I have been told to clean my air intake valve but I cannot get the damn tube off! I feel that if I yank and pull on it, it's going to damage the tube. I am not seeing any obvious leaks anywhere. One thing that is weird about my car, since I have bought it used a few years ago, my headlights/tail lights/blinkers go bad QUICKLY! Would this point to anything?
Any help?
Thanks
