Old 03-13-2016, 05:50 PM
thinmints thinmints is offline
Clunking noise front drivers side video link attached
96 Cherokee xj 4WD started to get a clunk noise, it would correct itself if i kept driving but now it seems to last longer any ideas
https://youtu.be/2Dc7qfbPZ3A
Old 03-14-2016, 12:47 AM
MikeCStig MikeCStig is offline
Re: Clunking noise front drivers side video link attached
The only 2 things I can think of are either a problem in the front differential, or worn spider gears in the cv joint. Is the problem more common going around corners, or does this happen in a straight line too?
"Ok, systems check; the battery is discharging, the oil temperature is very high, the oil pressure is very low, the engine temperature is off the end of the scale, I'm running out of petrol... but the clock is correct!"
-James May, in an old, worn out Lamborghini purchased for less than £10,000.
Old 03-14-2016, 12:20 PM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Questions: How many miles on your Jeep?
During the video, could you feel a jerkiness or resistance when turning the wheel and making the noise?
Can you turn the tire when 4wd is engaged? If so agree with a stripped gear.
Is the noise coming from the hub/wheel area or the differential area?
It definitely sounds like from your description that it lasts longer definitely indicates a failing part. It could even be a bearing; next time you drive somewhere, compare the temperatures of the front wheels. If the side making the noise is hotter, then that would point me toward the bearing.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 03-25-2016, 01:10 AM
just straight, doesn't do it going backwards, i can put it in 4wd and no problems. and it seems only to happen when its wet outside. im going to put new wheel hubs on ( i have 350k on my rig) so while im doing that i might just replace the u joints as well
