Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 03-10-2016, 10:42 PM
aleekat aleekat is offline
Cruise Control set switch
Cruise on/off works. Light on the dash. Some days pressing the "set" switch engages immediately. Other days, press it 20 times, nothing. Guessing switch contacts could use some cleaning/replacing. Service manual doesn't address how to pull the switch on the steering wheel...Tips?
Post back, that's what makes Forums Work.
Old 03-11-2016, 06:38 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: Cruise Control set switch
What year is your truck, 2003?
Manual or automatic trans.
The picture I'm looking at of a 2003 steering wheel shows screws on the back side of the steering wheel that hold the switches in place.
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
Old 03-12-2016, 12:25 AM
Yes, 03. auto.....thanks chris...
Old 03-12-2016, 06:09 PM
Thanks Chris. Just one screw. But switch doesn't look cleanable. Looks like junk yard time.
Old 03-12-2016, 06:38 PM
AF - Advisor
It would be nice if you could get someone to hold the steering wheel while you jumper those wires on a test run to be sure it's the switch.
Old 03-12-2016, 08:59 PM
That's a thought...
Old 08-19-2016, 12:19 PM
Well, been awhile since posting. Only 3 wires run into the switch that actually has 2 switches in it. Also found out this part was only put on 2003-2004 and discontinued. No one in US has it. Still looking for used. Part number is 56045779aa. Google search shows it but all places don't have it in stock.
