Old 03-10-2016, 06:48 PM
Iknownothing_ Iknownothing_ is offline
2004 Honda Accord LX Odd Sounds (Help!!) - with Video
https://youtu.be/_-4CuA3o7PU
Engine: 2.4 L
119,400-ish miles
See above video link.
I've been having this odd sound occur while I accelerate - sort of like a grinding sound (about 7 seconds into the video). It might be a bit difficult to hear over the other sound coming from my car... It occurs a lot more frequently when it's cold, when I'm accelerating, and when I am turning while I accelerate.
Also, the more obvious noise that occurs throughout the entirety of the video just began today. It does not occur while I'm stopped and it began when I stepped on the brake a little harder than usual...
Any input would be appreciated, because I know nothing about cars.
Thank you!
Old 03-11-2016, 07:44 PM
MikeCStig MikeCStig is offline
Re: 2004 Honda Accord LX Odd Sounds (Help!!) - with Video
The scraping/grinding sound 7 seconds in, I'm not sure about. The constant sound could be a brake issue. It sounds like worn pads scraping against the rotors. That's something you'll want to look into right away because something like that could turn from a new set of brake pads into warped rotors and even the calipers could go bad.
"Ok, systems check; the battery is discharging, the oil temperature is very high, the oil pressure is very low, the engine temperature is off the end of the scale, I'm running out of petrol... but the clock is correct!"
-James May, in an old, worn out Lamborghini purchased for less than £10,000.
Tags
accord , honda , problem , sounds , video
