Old 03-10-2016, 03:18 PM
stratos75's Avatar
stratos75 stratos75 is offline
Peterbilt 379
Finally, I have decided to build a truck. It is an iconic truck of the last millennium, the Peterbilt 379 with long hood. As a donor the Peterbilt 378 Long Hauler from Italeri was choosen.
I have started with a frame.
The front suspension was lowered.
Then the rear suspension was lowered too.
I have bought some additions from the Czech Truck Model (CTM).
Best regards, Mikhail
Old 03-10-2016, 03:52 PM
stratos75's Avatar
Re: 1/24 Peterbilt 379
Numerous marks of pushers were filled with a Tamiya putty.
The most of the chromed parts were cleared.
The cabin.
The windshield washer tank have an incorrect shape and place.
The air intake hole has an incorrect place too.
The muffler ends were a bit changed to have clear exits.
Some putty on the front end.
Assembling of air filters and fuel tanks.
A rework of the firewall.
A filling of voids in cylinders.
The door in a sleeper was opened.
There will be a girl inside a sleeper.
Old 03-10-2016, 05:22 PM
kopek kopek is offline
Is there a detail up set for the girl?
Oh, sorry, model is looking good.
Old 03-10-2016, 07:52 PM
stratos75's Avatar
kopek: Thank you! This girl was ordered by me on the Shapeways:
http://www.shapeways.com/product/KXL...ionId=57715332
On the next step I have decided to make a more correct front leaf springs. The front ends were cut.
The rear halves were copied in silicone.
I suddenly found that the earrings are tilted in the wrong direction.
This mistake was fixed.
Old 03-10-2016, 08:41 PM
stratos75's Avatar
The frame. It was the most complex part in this build, because I decided to give it more correct look and stretched it on 20 mm. Here you can see how many works were done.
The openings in crossmembers were added.
The real frame.
I have tried to give them a correct shape after the cutting of the frame.
The quick dry assembly to find the overall length of the truck. I have choosen the last version.
The real crossmember.
The further disassembling and modifying.
Old 03-10-2016, 10:37 PM
quadzero's Avatar
quadzero quadzero is offline
Incredible work, will be following along on this.
Old 03-11-2016, 07:39 AM
stratos75's Avatar
This is the fuel tank bracket.
In a real life it looks like this.
And this is my modification of the kit's bracket.
Then it was copied.
Old 03-11-2016, 10:05 AM
stratos75's Avatar
The rear propshaft. Out of the box.
With my modifications.
Before and after.
In its place.
The steering rod was made from copper wire.
I have bought the resin front hood. Unfortunately, it haven't matched to the cabin and to the front grille. It was widened and smoothed out by two component filler.
The front grille was modified too.
Later on the rivets will be added to the hood and to the grille.
Old 03-11-2016, 11:22 AM
stratos75's Avatar
The fuel tanks. I want to install a long tanks into my Pete. The standard tanks were extended.
Then the weld seams were added.
I have bought the Caterpillar 3406 engine. It will be installed in my Pete.
And I plan to change the wheels and tyres from 22.5" to 24.5". I have started to create a 3D model of new wheels.
Old 03-12-2016, 07:42 PM
stratos75's Avatar
It's time to make holes for rivets. I have found useful photos, print one of them and have used it as a template.
Here is the result. I have used a drill 0.4 mm diameter.
Old 03-18-2016, 03:45 PM
stratos75's Avatar
I will use the 0,5 mm rivets for the hood instead of 0,6 mm, which I have choosen earlier. They are matched to the cabin rivets more precize. The left is 0,6 mm and the right is 0,5 mm on this photo.
The cabin was adjusted, and the front brackets were glued to the frame after some changing.
I want to change the door hinges. These steel tubes and the needle of the syringe will be used.
Old 03-20-2016, 11:53 AM
stratos75's Avatar
I thought to make the cab to sleeper opening more correct, like this.
But then I decided to make a wide opening.
This is what we have out from box.
And the rear air suspension.
The suspension should be lowered. I have started to modify it.
The paper template was used for the new opening.
It's time for the cab.
The starting point.
And the result.
Old 03-21-2016, 01:42 AM
NewTom's Avatar
NewTom NewTom is offline
Well done mate!
Very inspirational work! Great attention to details!
Can I just ask what do you use to cut those panels? I mean those cuts looks amazingly straight and sharp.....
Old 03-21-2016, 04:11 AM
stratos75's Avatar
Thank you Thomas!
I use a model knife and etching saws (0,1 mm and 0,15 mm). And, of course, a steel ruler for straight lines.
Old 03-22-2016, 08:06 AM
NewTom's Avatar
Thanks Mikhail!
I also use PE saw to open up car's doors but I could never get that sharp and clean cut as you do. I should get some lessons from you....
Keep up the good work! I'm looking forward to more updates!
Cheers, T
