Old 03-09-2016, 06:08 PM
tuffy65 tuffy65 is offline
Front wheel bearing
How hard is the front wheel bearings to change? I've done this on a Taurus is it about the same? This is on a 2001.
Old 03-09-2016, 07:59 PM
Mac2002 Mac2002 is offline
Re: Front wheel bearing
On my 2000 Windstar, right side, the cv joint has to removed from the hub first as the bearing mounting bolts are accessed from the back side of the hub. Pop out the lower ball joint and the outer tie rod from the hub and press out the cv joint with a puller. Then remove the bearing mounting bolts and the bearing. You will have to pull hard on the strut to get it out of the way. * I cussed Ford for this as my 1991 Chevrolet Lumina van had the bearing mounting bolts on the outside of the hub, easily removed and the bearing removed without touching the ball joint or tie rod. Well thought out.
Old 03-09-2016, 09:20 PM
Ed_Strong's Avatar
Ed_Strong Ed_Strong is offline
Son of a Mechanic
https://www.youtube.com/watch?v=JYTfU03HXOo
just follow this guys instructions and you'll be done in no time... thats how I do mine! No need to remove the axle or suspension parts...!Even tho hes working on a Ford Taurus... the process is exactly the same for the Windstar
Current Rides:
2018 Honda Pilot EX-L - 3.5L V6 -{|}- 2004 Toyota Matrix XR 4WD 1.8 I4
________________________________________
Past Rides:
2000 Ford Windstar LX - 3.8L V6 SFI - {|} - 2003 Ford Expedition XLT - 4.6L V8 SFI
2005 Chevrolet Malibu LS - 3.5L V6 SFI - {|} - 1991 Chevrolet Corsica LT - 3.1L V6 MFI
1995 Dodge Grand Caravan SE - 3.3L V6 MFI - {|} - 1980 Ford Mustang - 3.3L L6 1BBL
Old 03-10-2016, 12:02 PM
Thank you for the help guys. The video was helpful.
Old 03-10-2016, 10:29 PM
Thank you for the video. Although its been a little while since I did the bearing replacement, I was sure I didnt have enough room to get a socket on the top bolt without completely removing the cv joint from the hub. If I ever have to do it again, I guess I'll pay more attention.
Old 03-11-2016, 11:32 AM
scubacat scubacat is offline
I recommend popping the ball joint out. Then you can push the axle back. It's really not much more work and will make accessibility a LOT easier. (It'll probably be quicker and will allow you to simply remove the 3 bolts without any hassle.)
If there's a lot of rust, that chisel won't be nearly enough to break it loose. I had to remove the knuckle completely and beat the hub out with a sledge hammer.
Old 03-12-2016, 07:32 PM
Thanks for your suggestions.I will probably pop out the axle and ball joint.
