Old 03-08-2016, 10:02 PM
rcweston rcweston is offline
Need help with removing or repairing window tinting film
1998 Lumina standard 3.1 200+k.
When I purchased this car it came with tinted window in the back seat doors and the rear window. It was great and I really liked it for 10-12 years until last year when the tinting started to bubble. Now a year later the back window is so bubbled that it appears as the glass used in bathroom shower stall defusing privacy glass. It is bubbles ¾ inch to 1 ½ inch that are surrounded by1/4 inch pieces of the film that is still very well attached to the glass. It is impossible to see through it!
The bad part is that the tint film is adhered to the inside of the glass were the defrost electrical lines that go across the window, adhering to both the glass and the electrical resistant lines. One little scratch and the defrost line no longer energizes to defrost the window.
So, how can I ether fix the bubbled film or remove the tint film completely without destroying the defrost lines?
The side windows are starting to bubble now also, similar to what the back window looked like last year.
Has anyone had experience with this problem?
Old 03-09-2016, 09:56 AM
maxwedge maxwedge is offline
A990 racer
Re: Need help with removing or repairing window tinting film
Google how to remove glass tint, plenty of info.
Old 03-09-2016, 10:01 AM
brcidd's Avatar
brcidd brcidd is offline
My insurance company replaces glass for $4 on my premium. A glass you cannot see through is just like a shattered window IMO. Why not see if your policy will replace your rear window?
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
The Following User Says Thank You to brcidd For This Useful Post:
rcweston (03-12-2016)
Old 03-09-2016, 10:14 AM
TBirdBob TBirdBob is offline
When the 3M rear window tint began to bubble and fail on my car, I called the company that installed it to make an appointment for repair. The removal took several hours because it was critical to go slow and not damage the defroster wires. If you can rent a steamer it will help in loosening the film.
The Following User Says Thank You to TBirdBob For This Useful Post:
Old 03-12-2016, 10:20 PM
thanks for the tip. I need to get something done to get rid of the film!!
Old 03-13-2016, 12:12 PM
http://www.wikihow.com/Remove-Window-Tint
Old 06-19-2025, 06:07 AM
clairehudson clairehudson is offline
Hey, I’ve dealt with a very similar issue on an older Civic I owned, the rear tint had baked under the sun for over a decade and turned into a bubbled mess, just like you described. It’s especially tricky when the defrost lines are involved because one wrong move and they’re gone for good.
From my experience, trying to peel off the film manually often leaves the adhesive behind, which then becomes a nightmare. What worked best for me was using a steamer to soften both the film and the glue. Start at a corner and work slowly with a plastic scraper or even a credit card to lift it without scratching the glass or damaging the defrost lines. It’s tedious, but it beats losing the defrost altogether.
That said, if you're unsure or want to avoid the risk altogether, it might be worth having a professional handle it. I found out the hard way that a botched removal can cost more in repairs. A local shop like OC Tint Solutions could probably help remove the old tint safely and even reapply high-quality film that lasts much longer. They also offer insight into modern films that resist bubbling and are much easier to maintain.
Best of luck, old cars with baked-in tints are tough, but with the right tools or help, you can definitely restore visibility without losing your defroster!
Old 06-19-2025, 03:44 PM
A990 racer
Good advice, but this is a 9 year old inactive thread.
