Go Back   Automotive Forums Car Chat > Chevrolet > Uplander
Old 03-08-2016, 06:37 PM
Maker1351 Maker1351 is offline
2008 Chevy Uplander
Got a check engine light 2 days ago. Got a scanner to pull codes. Prior to pulling codes, wife had a no start at the gas station. Cranked, acted like it wanted to start but nothing. Finally, held throttle down and started. Fine every since. Pulled codes and got P0496. Evap system purge flow. Can't see that causing a no start. Gonna start w/ fuel pump. Anyone know operating fuel psi. 3.9 w/ no flex fuel. Thanks in advance.
Old 03-08-2016, 08:23 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: 2008 Chevy Uplander
Holding the throttle down while starting on a fuel injected vehicle actually shuts injectors off, so if it started after she held the throttle then it was flooded for one reason or another.
Old 03-09-2016, 04:07 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Yes, a purge valve can and will cause a no start after fuel fill. Stuck open will push fuel vapors into the intake, flooding it. Replace the purge valve. I'v seen this before.
Old 06-20-2016, 12:39 PM
Wildbill_NJ Wildbill_NJ is offline
I had an issue with our 06 not starting unless you stepped on the gas pedal slightly and it turned out to be carbon buildup in the throttle body where the butterfly seals. some 2+2 fixed it right up no more starting problems
