trnsmission problem
hi,
can somebody tell me why when push on gas and rpm get's over 2000 the tranny it's starting to crying at any gears |
Re: trnsmission problem
What is the fluid level? What is the fluid condition? Is there evidence of air entrained in the fluid when it is checked with the engine running (standard procedure)?
Does the transmission shift through the ranges automatically? Does it shift through the ranges firmly if operated manually? Is there any similar noise when revving the engine to 2,000 RPM while in Park?
Permanent seat assignment on the Group W bench... Automotive Forums Survival Guide |
hi,
fluid level ok at max in hot tranny ,also new oil and filter about 1000miles ago tranny shift and hold position well just when get's hot start also to hard-shift at any gear yes , it does make the same noise of crying in park condition over 2000rpm |
Since the noise occurs at 2000 engine RPM with the vehicle moving it could be a few things in the transmission or it could be the engine or the accessories like the alternator, PS pump or water pump. Just to be certain the noise is not due to an external accessory it may be helpful to remove the accessory belt and start the engine to test it again. About the only thing moving in the trans when in Park is the torque converter, pump, and drive chain and sprockets. If the fluid is not foaming the pump may not be the issue. There was a TSB (0-07-30-007A) regarding the chain, sprockets, and sprocket support bearings on the transmission, and that may be the cause. There is no good repair for this issue short of removal and replacement of the chain and sprockets. Transmission oil additives will not improve this. If the trans is removed for repair it would only make sense that new clutches and steels would be installed (complete rebuild). A used transmission is likely to have similar symptoms unless it is rebuilt to replace worn parts.
| The Following User Says Thank You to Blue Bowtie For This Useful Post: | ||
giorgio959 (03-06-2016)
Hi giorgio959 !
Most likely you may have a pressure control solenoid going out, which would explain the hard shifts and whine. Best to check the computer for any codes relating to the trans. Good luck to you!!! ... I would like to complement the - if I recall correctly, this tsb indicates that there may be dirt in the valve, causing the condition. If this is the case, similar dirt may also be in the valve body. You should clean or replace the valve body . |
