Go Back   Automotive Forums Car Chat > Toyota > Tacoma
Old 02-29-2016, 07:27 PM
Bob704 Bob704 is offline
Check engine light and gas cap
Auto Zone checked for engine light and said I needed new gas cap. Have driven for over 75 miles and with at least a dozen start-stops with new cap and light is still on. I have a Tacoma 2002. What do I do next? Thanks for any help.
Old 02-29-2016, 08:52 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: Check engine light and gas cap
Did they clear the code once you got a new cap?
Old 02-29-2016, 09:03 PM
MikeCStig MikeCStig is offline
You can't always fix the problem and expect the light to just go away. You may have to reset the engine computer. Sometimes it's as simple as disconnecting and reconnecting the battery, sometimes there's more to it. I'm sure the procedure specific to your truck isn't that hard to find.
"Ok, systems check; the battery is discharging, the oil temperature is very high, the oil pressure is very low, the engine temperature is off the end of the scale, I'm running out of petrol... but the clock is correct!"
-James May, in an old, worn out Lamborghini purchased for less than £10,000.
Old 02-29-2016, 09:24 PM
Stealthee's Avatar
With a code reader its as simple as hitting "clear code"...
Old 02-29-2016, 10:04 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Pull the ECM fuse for a couple of seconds. It's in the engine compartment by the battery.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 03-13-2016, 09:16 PM
I got the light to go off by disconnecting the battery and it stayed off for short while and is now back on again. Should I take it back to Auto Zone again or does anyone know what the trouble might be? Thanks to everybody for your help, Bob
Old 03-14-2016, 05:11 AM
Stealthee's Avatar
You need to have the code read to figure out what is tripping the light. My guess is you probably have an evap problem.
Old 04-02-2016, 09:08 PM
Checked again and very sure have a leak in vacuum. Is there anywhere I can get a diagram showing the path of the vacuum hose line? Looking at the engine compartment I can not tell where the line starts at the intake manifold. A picture or diagram would be very helpful. Many thanks, Bob
Old 04-02-2016, 09:44 PM
Brian R.'s Avatar
Resident Chemist
Send me your e-mail address and I'll send you a link to a manual which may be useful.
Old 04-04-2016, 09:04 PM
Thanks Brian my email is [email protected]
Old 06-28-2016, 12:33 PM
Hondaman56 Hondaman56 is offline
The gas cap is only the first thing to try for EGR codes. Its a quick fix and inexpensive if that happens to be the cause. My Taco did the same thing and it ended up being the EGR valve. Its a $35 part from Toyota. Its located on the driver side of the intake and you can replace it in about 15 minutes with a 10MM wrench.
