Old 02-26-2016, 06:16 PM
Robert85387 Robert85387 is offline
Ckp
Hi i need some help I have a 1998 Chevy 5.7 pick up took out CKP because leaking oil. The o ring was smashed replace o ring put CKP back in turns over will not fire. Code 336 comes up when tesred. Replaced CKP and pigtail connector just to be sure no broken wires . Truck still turns over but will not fire ran all the test i could everything test good but same code and will not fire
Old 02-27-2016, 03:47 AM
Schurkey Schurkey is offline
Re: Ckp
Did it run before you removed the crank sensor?
For the good of the Free World, DEMAND COMPENSATION FROM CHINA for their release of the Virus Originating in the Wuhan Laboratory, released (intentionally or negligently) into the world in 2019 (VOWL-19). Ten trillion to start with, increasing as needed from there, PLUS compensation for the sickened, and "wrongful death" settlements for the families of those who didn't survive. END trade with Communist China.
Old 02-27-2016, 05:18 AM
Re: Ckp
Yes it ran great
Old 02-27-2016, 10:27 AM
j cAT j cAT is offline
Re: Ckp
Originally Posted by Robert85387 View Post
Yes it ran great
the CKP can be hard to seat in the engine properly if not in the exact position it will not run correctly . try to place into this exactly as it was..... disconnect the negative to the battery to make the PCM start from the factory set points . if not fixing it , then may need to be programmed by a GM dealership with the proper diagnostic programmer tool. forgot PUT THE OLD ckp BACK IN !!!!!!!
Old 02-27-2016, 09:25 PM
Re: Ckp
Thanks for the information will try
