Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 02-26-2016, 09:45 AM
rkc1202 rkc1202 is offline
98 3500 fuel issues
Shut the truck off one afternoon to check brake lights,never to start again.Pump was replaced recently.Turn the key on ,no pressure.No power to control side of relay.Jumped 87 and 30 in circuit and pump runs,56 psi. Fuel gauge is freaked out and goes way past full when key is turned on.So connected a scanner and it fails to link to the truck.When problem first occurred I had spark to engine and now aside from fuel problem I have no spark.HELP Im really at a loss here. I tested and retested all fuses.The fuel relay circuit grounds test good.Changed relay. any suggestions?
Old 02-26-2016, 12:17 PM
maxwedge maxwedge is offline
A990 racer
Re: 98 3500 fuel issues
What engine is in this truck, 454 Vortec?
Old 02-26-2016, 05:49 PM
777stickman 777stickman is offline
In the "underhood fuse-relay" center check these fuses for power in both the "start" & "run" position.
Pull the starter relay so the motor Is not spinning while checking this.
1. IGN-E 10a
2. ECM-1 20a
3. ENG-1 20a
If there are any power issues on these fuses, replace the Ign Switch.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
The Following User Says Thank You to 777stickman For This Useful Post:
rkc1202 (02-29-2016)
Old 02-27-2016, 09:14 AM
j cAT j cAT is offline
my guess is the PCM/connectors @ PCM or the grounding points .
The Following User Says Thank You to j cAT For This Useful Post:
