Old 02-23-2016, 11:31 AM
ed_2006 ed_2006 is offline
2000 Caravan 3.3l spark plugs replacement
Hi Fellas,
I recently changed my spark plugs and wires on my 2000 3.3l caravan. I removed the wiper cowl and intake plenum to do this. I bought a new gasket, but did not use any gasket sealer. I torqued it down with 15 ft/lbs. But it is leaking and idling high. Should I use gasket sealer, and is this the right torque spec? The spec is a little sketchy as I have seen other sites that say to use 21 ft/lbs. I know the head is aluminum, so before torquing it down with 21 ft/lbs, I figured I better check here!
Old 02-23-2016, 09:43 PM
pmpmrs@amigo.net's Avatar
[email protected] pmpmrs@amigo.net is offline
Re: 2000 Caravan 3.3l spark plugs replacement
Why in the world would you pull the intake ? Or even the wiper cowl ?
There is plenty of room to reach over the coil pack to get at the rear plugs.
Just asking ????
Mike
Old 02-23-2016, 09:59 PM
Just asking ????
Mike
My motor has the intake that wraps around the rear side of motor. Believe me, I tried reaching the two plugs without removing those two items, but there was no way in hell. I was actually able to reach the number 1 plug which is the left most plug of the three rear ones without moving intake. I didn't remove the intake completely. Just moved it forward about an inch.
