Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon
Old 07-01-2003, 09:14 AM
pestw pestw is offline
Question code 31
i need to know what it's going on, well first i get this VIN code that ,means "Evaporator purge flow monitor failure or evaporator solenoid circuit problem" and the idle speed of my neon it's 500 rpm and when i turn on the A/C it will go up to 1000 rpm but eventualy slow down to 500 rpm please someone help me if you have pictures of the evaporator i will help me better to understand how to fix it.
thanks
Old 07-02-2003, 07:48 AM
Unhappy why no one helps me???
hey why no one answers please I need help with this
Old 07-02-2003, 05:48 PM
KatWoman KatWoman is offline
I got your email. I havent had this code before and don't have my Haynes manual on me. I made a post on Neons.org and am awaiting a reply
Old 07-13-2003, 02:48 AM
Scorpio7's Avatar
Scorpio7 Scorpio7 is offline
Send a message via Yahoo to Scorpio7
Post Code 31
The code 31 shows up in my book as a canaster purge solenoid failure.
The only problem is that this code also only shows up for Chrysler Cars on vehicles with special California emissions controls.
There for I am from Ohio and the codes dont work for me.
Best bet for you is to get ahold of one of your local Chrysler dealerships and see what they tell you..
Angelo...I Cant Tell You
Old 01-15-2004, 05:46 PM
OxNeon OxNeon is offline
Re: code 31
Yeah, Code 31 is your canister purge solenoid. It gives a code if the voltage is off due to a faulty solenoid valve, or electrical connection or an air leak from the hoses. It's a pain to deal with because my car is passing the emissions with flying colors except for the OBDII Code 31 complaint.
I would check all of your hoses and check your connections, especially if you have idle problems as you described.
