Go Back   Automotive Forums Car Chat > Honda > Interior | Audio | Security
Interior | Audio | Security Tech forum to assist in Honda/Acura Interior, Audio and Security.
Old 01-31-2016, 09:11 PM
Helmuth48's Avatar
Helmuth48 Helmuth48 is offline
2001 Accord EX... Disable Alarm
OK...my alarm goes off late at night...moisture, rain, humidity...I live in Portand, Or.
So I want to disable it... I am a student...later I will get the cash and get is fixed right, but for now... I just want to disable it...so I not walk the whole neighborhood up.
So I have been told to disconnect the hood switch... some say..just unplug it and others say you need to short the connector with a jumper...
1. Does anyone have a picture of where the switch is near the hood latch.
2. Which method do I use ????
Ps....I am using my dad's log in to this forum...
Thanks ... Dylan....
Old 02-01-2016, 02:09 PM
Copytech99 Copytech99 is offline
Re: 2001 Accord EX... Disable Alarm
Look along the area above the radiator, and for wiring leading into the latch in the middle. My Civics have a connector available.
Just disconnect for testing. (your alarm may not set though)
Old 02-02-2016, 07:44 PM
Helmuth48's Avatar
OK...thanks... I just want to disable it for now....so do i just pull the connector from the sensor... or do I "jumper" the connector with a wire. My understanding is that the system will think the hood is OPEN and not arm....
Old 02-03-2016, 07:42 AM
When the hood is open the microswitch grounds the single line (Civic) so yes that line would need to be at ground to disable alarm from setting. (would think hood was open)
But, the hood latch may be what is triggering alarm, if you can find a connector inline with the wire leading to hood latch you could simply disconnect it for testing.
Old 02-05-2016, 05:41 AM
Helmuth48's Avatar
OK....thanks...I will give it a try. I also found out my battery was not staying at full charge...I am getting a new one.... thanks again....
Any change of getting a picture of the hood switch and the connector...i am not a car guy..
Old 02-05-2016, 07:09 AM
The hood switch is hidden in the latch.
The connector is just a single pin version of the others used throughout the car.
Look for a single wire leading to hood latch... that will be it.
Old 02-07-2016, 12:02 PM
Helmuth48's Avatar
OK...thanks.... got a new battery... shop, who I trust, did a load test and the battery is bad....WD40 all the door switches and the hood latch area...I am sure I got the switch....
Set the alarm....and so far so good...not went off in two days... time will tell....
Thanks to all..... Dylan...in Portland, Ore........
Old 02-10-2016, 05:03 PM
Helmuth48's Avatar
Well... too good too soon. It went off again at night .... Why always at night..I cannot figure that out... So I found the hood switch connector and disconnected it... let see what happens.... I hope the doors will lock....
Old 02-11-2016, 09:22 AM
They should lock.
Do you have any indicator for when the alarm is armed ?? (06-15 Civics have a red light in the cluster)
