Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 01-27-2016, 06:05 PM
rubs rubs is offline
2001 I30 stopping at idle
Hi,
2001 I30 with 187k miles was running fine until 2-3 days ago when I started and it stopped in about 1/2 mile and then not starting unless I press the accelerator and turn key at same time but stop immediately if i remove foot from accelerator, if i quickly try to move to D and drive then it stops again ~ 1/2 mile. Tow it to mechanic and he feels it most likely be MAF or IAC issue but he can't test as he don't have way to check it. I have a friend who thinks it might be a bad fuel filter. There is no check engine light. Mechanic increased the idle as temporary fix and I am able to drive it back home. Did anyone else had similar issue as I am not comfortable driving it as may break down again and dealer may charge lot of money to debug and fix the issue.
Thanks
--rubs
Old 01-27-2016, 07:24 PM
MikeCStig MikeCStig is offline
Re: 2001 I30 stopping at idle
IAC was my first thought too, find a mechanic who can test it and look into that.
"Ok, systems check; the battery is discharging, the oil temperature is very high, the oil pressure is very low, the engine temperature is off the end of the scale, I'm running out of petrol... but the clock is correct!"
-James May, in an old, worn out Lamborghini purchased for less than £10,000.
