Go Back   Automotive Forums Car Chat > Oldsmobile > Eighty Eight
Eighty Eight Includes the '97-'98 Regency and '96-'99 LSS Models
Old 01-26-2016, 06:13 AM
raptorgabe raptorgabe is offline
88 wont start when cold
I have a oldsmobile 1998 88 and when its cold it wont start at all! just cranks ! if u plug the engine block heater in however it will start right up! what could be the prob? in summer its fine just when its cold it has hell ! any help would be appreciated
Old 01-26-2016, 11:29 AM
maxwedge maxwedge is offline
A990 racer
Re: 88 wont start when cold
Many things can cause this, general tune up issues, low fuel pressure, poor fuel quality, dirty throttle body,marginal related engine sensors.
Old 01-26-2016, 12:14 PM
Tech II Tech II is offline
First, I would scan for codes.....
Second, on a cold engine, I would read engine data, and make sure the intake air temp sensor and the coolant temp sensor read the same........
Then you do the basics, like Max suggested.....
Also, try starting the car cold with the MAF disconnected, when it won't start....
Pull the vac line to the fuel pressure regulator, and check for the presence of fuel in the line.....
Try lightly stepping on the accelerator pedal(to open the throttle plate, just a little), and see if it starts.....
Have a can of carb cleaner handy....when it wont start, pull the snorkel off the throttle body, and have someone crank the vehicle while you spray carb cleaner into the throttle body(don't step on the gas pedal at all).......
Old 01-26-2016, 01:56 PM
Cool I will try this stuff ! Thanks everyone
